Actually I bought CYW954907AEVAL1F_Evaluation_Kit to test the RF parameters .I am new to WLAN testing .Could you please suggest me to understand and testing/measure the RF parameters.
harshini
RaktimR_11
25 solutions authored 10 solutions authored 5 solutions authored
Please check this thread WLAN RF testing which should help you in understanding the basics of RF testing part.
RaktimR_11
I want to test the kit(CYW954907EVAL 1F) WLAN 802.11n @40MHz bandwidth, if i change the commands as mentioned below also i'm not able to get 40MHz bandwidth for 5G/2.4G bands.Could you please help me how to set the commands
>> wl43909B0 --serial 8 band b --> b = 2.4 GHz, a = 5 GHz
>> wl43909B0 --serial 8 2g_rate -h MCS7 -b 40 --> 2g = 2.4 GHz, 5g = 5 GHz, -h = MCS0-MCS7, -b = 40 MHz bandwidth
Thanks&Regards,
harshini
Could you please help me for the above request
Thanks&Regards,
harshini
RaktimR_11
Please use the attached batch file which lists out the command sequence for 40MHz test. Place the file in C:\Users\<user_name>\Documents\WICED-Studio-6.2.1\43xxx_Wi-Fi\libraries\test\wl_tool ( by default it should be the installation loc, update it for your installation if required). Modify the batch file based on the com port number. Hope it helps!
Refer to https://community.cypress.com/servlet/JiveServlet/previewBody/2360-102-3-16504/002-23156.pdf this document for detailed usage of WL commands
Thank you.After adding this batch into C:\Users\<user_name>\Documents\WICED-Studio-6.2.1\43xxx_Wi-Fi\libraries\test\wl_tool, is it required to dump the code again into kit?
harshini
RaktimR_11
If you already have test.mfg_test application flashed in a CYW954907AEVAL1F EVK, there is no need to dump again as the mfg_test fw already have support for the WL commands used. Just running the batch file from command prompt should be sufficient.
Thank you
harshini
I am sending the pkteng_start 00:11:22:33:44:55 tx 100 1024 0 to test the WLAN kit in 802.11ac standard(5GHz band and 40MHzBW).While sending the packet,1024 bytes of data is going along with all payload data,header and preamble.How to find out pay load data alone in the whole 1024 bytes of data?Could u please help me hoe to finding out it.
Thanks&Regards,
harshini
RaktimR_11
You can use a sniffer like wireshark for that purpose to check the payload.
