Hi all,
I have installed new SDK for WICED wi-fi and Also burn the sample code provided in SDK via evolution board BCM943362WCD4_EVB .
My problem is I am not getting any wi-fi signal when i search from laptop.
Need Help on this matter.
Thank you in advance.
JoYi_1844281
Level 6
Level 6
100 sign-ins 100 replies posted 50 likes received
Which sample you burned into EVB ?
you should try the demo.appliance first !
Jone
Hi Jone,
I have burned the default one illustrated on example ,
I have used this command " make snip.scan-BCM943362WCD4 download run" , As it will burn (if i understood properly) default appliances one.
still I am not able to detect the wifi signal of WICED on my laptop.
Thanks..
The snip.scan act like station which NOT act like an AP.
You should see it show scan result on CONSOLE but detect it's WiFi signal!
Post the picture of your EVB
And whole output during you build and download to the board
First, Thank You for Your Replay, As you said, The screen Shot and EVB board no. is as below.
My EVB is BCM943362WCD4_EVB using WICED-SDK 3.1.2 ..
Also Not able to get the scan result on consol, If By demo Application it should work as AP, That also Not able to get.
Please tell me where i m mistaking.
Thank you in advance,
Did you follow Quick Start Guide to connect HyperTerm like to UART as console output ?
yes, I Did, That Problem Is resolved just now.
But now facing another question.
My application need more than 5 clients should connect with My WICED chip.
Is It possible.? How many clients can be connected with the WICED if i configure it as AP. ?
And what are other steps need to follow to program it accordingly...
Thank you in advance jone....
Did you read the README and document ?
Your question is already answered in it!
Hi Jone..
Thx for Reply.
Yes, I have read the docs and READ-ME, but not able to find it..
I quote here "AP mode when running with WPA/WPA2 encryption is limited to 4 STA clients"
Thx Jone.
Can u tell me if i do connection with out any encryption. Will it support more than 4 STA Clients?
If It does , I can do open connection as my need is to connect More than 5 STA clients.. !
You could try it by yourself!
Thx jone.
Yes I ll surely try for it....
thanks again...
Hi jone,
I also have tried making " demo.appliance-BCM943362WCD4" and downloaded .. still i was not able to get the wi-fi signal on my laptop from wiced board.
Thank you..
