Hi, I tried to install WICED studio version 6.4.0 on windows from here WICED-Studio 6.4.0 Installer (Windows) i did everything as described in README.txt file but after chosing directory where i want to install IDE occure error like this:
While i got around 200 GB free space on each partition of disc.
I am using windows 10 education and my java version is 8.
let me know if any information about my system or computer can help you solve this problem.
Thanks, Wojciech
Hi
Did you follow the steps mentioned in this blog post : WICED-Studio 6.4.0 Installer (Windows)
Even then if the issue persists, could you try
1. Installing WICED in a different directory.
2. Remove all the files related to WICED which could have been installed and repeat the process.
Murali
Hi Wojciech
There was a similar issue reported in this thread : Re: Can't install WICED Studio 6.2.1 on Windows machine
Do try the fix mentioned there and let us know if the issue persists.
Murali
I folowed the possible solution you linked, but that didn't work for me. Still the same problem.
Hi
Murali
I have had the same problem. Just couldn't install the IDE. I have followed all you suggestion.
Could you share your installation logs so that we could look into it and debug the issue?
Hi
As per your installation logs, i don't see a SDK installation folder that was selected. Did the installation not allow it and was it overlooked by mistake? Also could you try removing all files related to WICED and then try downloading and installing the software once again?
