WICED make file
lola_1650581
First like received
Hi,all:
     Do you have any document can tell me how to make a .mk file to the project.
KS_96
10 sign-ins 5 sign-ins 10 replies posted
It's actually quite simple. Here are the steps i see to create a .mk file.
Let us assume that you are creating application in apps/snip/user_app.
1. You name the file as user_app.mk. Define name of the app
2. Add all the source file using
     $(NAME)_SOURCES +=user_app.c
3. Add required components, for instance
    $(NAME)_COMPONENTS += protocols/MQTT
3. If you use any other resources like certificate or html page then add them under
    $(NAME)_RESOURCES  := apps/aws_iot/rootca.cer
4. In case you want to define WLAN credentials separately then,
   WIFI_CONFIG_DCT_H := wifi_config_dct.h
5. if you have any Global define then define them here, for instance
   GLOBAL_DEFINES += NO_AP_INTERFACE
6. Optionally, you can also define if this for specific platform using
   VALID_PLATFORMS :=
Look at either apps/snip/scan/scan.mk or apps/test/console/console.mk for a more detailed example
KS_96
   VALID_PLATFORMS :=
