TaGo_2353976
Level 4
Level 4
I'm designing STM32+CYW43438 module with WICED.(WICED ver is Wiced_006.002.001.0002).
I'd like to know following points.
1. In default, where is clm_blob stored ?
2. When I added countries to my regulation and made clm_blob via Mycase ,
     how can I program to my module ?
<Back Ground>
Usually, I used host based IC ,such as CYW4373 or CYW43455 with Linux.
In this system, we changed clm_blob binary itself in my Linux but I'm not familiar with WICED so I don't understand basic point as above.
I hope to get anyone help.
Thank you.
--TAK
RaktimR_11
500 replies posted 250 replies posted 100 replies posted
Please check the New Document Release: AN225347 - Cypress Wi-Fi CLM Regulatory Manual​ for details on how to replace the default clm blob present in WICED SDK. Usually, clm blob resides in the resources directory; i.e it goes in as a part of resource filesystem binary. Just like linux chip-sets, you need to modify the clm blob in 43xxx_Wi-Fi/resources/firmware/4343W, detailed procedure can be found in section 8.1 of the above mentioned document.
RaktimR_11
