When using the "wiced_dct_read_wifi_config_section ( )" to read the WiFi settings from the DCT area, and if the WiFi password contains a "0" in its string,
then the password is read incorrectly !!
example:
password = 24C51A718F --> reading it from the DCT = 24C51A718F     (good)
password = 24C50A708F --> reading it from the DCT = A1E011DD53    (not good)
so there is a bug with the read function, however, the write function is OK.
The latest SDK uses a different function. And I haven't tested the new function yet.
VikramR_26
25 sign-ins 10 sign-ins 10 comments on KBA
thanks for letting us know, we will look at this.
Thanks for looking into this .. by the way this bug is in SDK 2.4.1
Do you see it latest SDK release ? Since we do not fix issues for older version of SDK.
