MiTo_1583836
I just went through the re-installation of SDK 3.7.0-3 on Mac OS X and came across few things that I would like to highlight in this post. It may be helpful for someone else.
The installation is performed on El Capitan: 10.11.6, the WICED SDK is downloaded from here: WICED Wi-Fi Documents & Downloadsselect a *.7z file, those are for Mac OS X.
The steps are:
  1. Run the instance of WICED Wi-Fi Eclipse CDT. If Eclipse is not installed yet: please use this one here: WICED-SDK-2.4.1 IDE & SDK [Mac OS X Package Installer]There is only one release of the Mac OS X Package installer so you have to start with this version even though the SDK is not the latest one!
  2. When Eclipse is up and running, do File->Import->Existing Project Into Workspace
  3. Under "Select root directory" select the decompressed *.7z SDK that you just downloaded above.
  4. Select "WICED-SDK-xxx" (for example: WICED-SDK-3.7.0-3) under Projects.
  5. Usually I would not select "Copy projects into workspace" (that's just my current configuration).
  6. Working sets not selected for this example.
  7. Press "Finish".
  8. You should see now under the imported project called WICED-SDK-xxxx (for example: WICED-SDK-3.7.0-3) under "Project Explorer".
  9. Also the "Make Target" window should be populated with the project.
  10. If you see folders and source code under the Make Target, just press the button called "Hide Empty Folder", this will keep the rules only (cleaner!).
  11. At this point you should see the build window with an error similar to the one below (see Logs of error during SDK install, Step 11 below)
  12. The make used to build is not the right one, you need to use the make provided with the SDK.
  13. Configure the proper make file via: Project->Properties->Builder, remove the check for "Use default build command", replace the make with: ${workspace_loc:/WICED-SDK-3.7.0-3}/make
  14. Press Apply and close the window.
  15. Create a rule in the Make Target window as follow: snip.scan-BCM943362WCD4
  16. Execute the the build by clicking on the Target rule created above, see successful logs under STEP16 below
Logs of error during SDK install:
Step 11:
make all
tools/makefiles/wiced_toolchain_common.mk:202: *** incorrect 'make' used (/Applications/Xcode.app/Contents/Developer/usr/bin/make) - please use:  (Windows) .\make.exe <target_string>    (OS X, Linux) ./make <target_string>.  Stop.
STEP 16:
**** Build of configuration Default for project WICED-SDK-3.7.0-3 ****
/Users/mickael/Documents/WICED_WiFi/WICED-SDK-3.7.0-3/make snip.scan-BCM943362WCD4
MAKEFILE MAKECMDGOALS=snip.scan-BCM943362WCD4 OTA2_SUPPORT is disabled
Making config file for first time
| IMPORTANT NOTES        |
| Wi-Fi MAC Address        |
|    The target Wi-Fi MAC address is defined in <WICED-SDK>/generated_mac_address.txt                 |
|    Ensure each target device has a unique address.                                                  |
| MCU & Wi-Fi Power Save        |
|    It is *critical* that applications using WICED Powersave API functions connect an accurate 32kHz |
|    reference clock to the sleep clock input pin of the WLAN chip. Please read the WICED Powersave   |
|    Application Note located in the documentation directory if you plan to use powersave features.   |
Building Bootloader
Finished Building Bootloader
Processing resources
Creating security credentials
Making DCT image
Compiling App_Scan
Compiling Platform_BCM943362WCD4
Compiling WICED
Compiling Lib_SPI_Flash_Library_BCM943362WCD4
Compiling Lib_GPIO_button
Compiling WWD_ThreadX_Interface
Compiling WICED_ThreadX_Interface
Compiling WWD_for_SDIO_ThreadX
Compiling Supplicant_BESL
Compiling Lib_DNS
Compiling NetX_Duo
Compiling Lib_Wiced_RO_FS
Compiling STM32F2xx
Compiling Lib_TLV
Compiling Lib_base64
Compiling Lib_Linked_List
Compiling Lib_crypto_open
Compiling Lib_micro_ecc
Compiling WWD_NetX_Duo_Interface
Compiling WICED_NetX_Duo_Interface
Compiling common_GCC
Compiling STM32F2xx_Peripheral_Drivers
Compiling Lib_Ring_Buffer
Compiling Lib_crc
Compiling Lib_DHCP_Server
Compiling STM32F2xx_Peripheral_Libraries
Making build/snip.scan-BCM943362WCD4/libraries/App_Scan.a
Making build/snip.scan-BCM943362WCD4/libraries/Platform_BCM943362WCD4.a
Making build/snip.scan-BCM943362WCD4/libraries/WICED.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_SPI_Flash_Library_BCM943362WCD4.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_GPIO_button.a
Making build/snip.scan-BCM943362WCD4/libraries/WWD_ThreadX_Interface.a
Making build/snip.scan-BCM943362WCD4/libraries/WICED_ThreadX_Interface.a
Making build/snip.scan-BCM943362WCD4/libraries/WWD_for_SDIO_ThreadX.a
Making build/snip.scan-BCM943362WCD4/libraries/Supplicant_BESL.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_DNS.a
Making build/snip.scan-BCM943362WCD4/libraries/NetX_Duo.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_Wiced_RO_FS.a
Making build/snip.scan-BCM943362WCD4/libraries/STM32F2xx.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_TLV.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_base64.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_Linked_List.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_crypto_open.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_micro_ecc.a
Making build/snip.scan-BCM943362WCD4/libraries/WWD_NetX_Duo_Interface.a
Making build/snip.scan-BCM943362WCD4/libraries/WICED_NetX_Duo_Interface.a
Making build/snip.scan-BCM943362WCD4/libraries/common_GCC.a
Making build/snip.scan-BCM943362WCD4/libraries/STM32F2xx_Peripheral_Drivers.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_Ring_Buffer.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_crc.a
Making build/snip.scan-BCM943362WCD4/libraries/Lib_DHCP_Server.a
Making build/snip.scan-BCM943362WCD4/libraries/STM32F2xx_Peripheral_Libraries.a
Making snip.scan-BCM943362WCD4.elf
Making snip.scan-BCM943362WCD4.bin
                                  |         |  Static |
              Module              |  Flash  |   RAM   |
App                               |     404 |       0 |
crc                               |    1060 |       0 |
Host MCU-family library           |   13821 |    2737 |
Interrupt Vectors                 |     388 |       0 |
libc                              |   23551 |    3064 |
Networking                        |     989 |    8523 |
NetX-Duo - Interfaces & Stacks    |       0 |      16 |
Other                             |    3678 |      92 |
Packet Buffers                    |       0 |   23086 |
platform                          |    1024 |     168 |
RAM Initialisation                |    2316 |       0 |
resources                         |      16 |       0 |
Ring_Buffer                       |     116 |       0 |
Startup Stack & Link Script fill  |       9 |       3 |
ThreadX                           |    7868 |     396 |
TLV                               |      28 |       0 |
Wi-Fi Firmware                    |  210624 |       0 |
WICED                             |    3909 |     980 |
WWD                               |   14391 |    3007 |
TOTAL (bytes)                     |  281876 |   42072 |
Build complete
Making .gdbinit
