Sep 19, 2018
02:44 AM
Sep 19, 2018
02:44 AM
When I place breakpoints, they are not 'loaded' if I'm not running the firmware, i.e., there's no tick placed next to the breakpoint in the IDE.
When I run the firmware and place a breakpoint, then it is properly loaded and the firmware will break as intended.
This is annoying, because I have to reload breakpoints on every run!
Is there a solution to this?
- breakpoint
10:38 PM
Sep 30, 2018
10:38 PM
You have to load the FW; otherwise there won't be any ticks placed next to the breakpoints unfortunately and it won't work as expected.
