WICED-Studio-6.0.1 on BCM94341WCD1_2, ble connect reason code always return 0x100 (L2CAP_CONN_CANCEL)
We are using the WICED-Studio-6.0.1 on BCM94341WCD1_2 and write a simple APP to try to connect the ble device.
Now we scan the ble device and try to call the wiced_bt_gatt_le_connect() to connect the ble deivce, but the gatt_event_callback() will always return connection fail and the reason code is 0x100 (L2CAP_CONN_CANCEL).
We can't find more info for this reason code.
Have any suggestion for it?
I tried your application but with WICED 6.0 build and didn't find any issue. Attached is the log I see at my end.
Have you tried with a different peripheral?
