There seems to be a problem with the LwIP network stack -
running "make snip.scan-BCM943362WCD4-FreeRTOS-LwIP-SDIO"
Gives this error:
Compiling WICED_LwIP_Interface
Compiling Supplicant_BESL
WICED/network/LwIP/WICED/wiced_network.c:81:1: error: unknown type name 'NX_IP'
NX_IP* wiced_ip_handle[ 3 ] =
It looks like the LwIP wiced_network.c file has some code from NetX?
[WICED_STA_INTERFACE] = STA_IP_HANDLE,
[WICED_AP_INTERFACE] = AP_IP_HANDLE,
[WICED_P2P_INTERFACE] = P2P_IP_HANDLE
I downloaded the sources from the 7z.zip file, and also produced the same problem when installing the IDE and running the make from there.
If there's anything more you need from me to reproduce the problem just let me know. I hope it's an easy fix - we're eagerly awaiting the 3.1.2 release as it fixes problems we're having with LwIP on 3.1.1.
Exact same issue here. Any fix yet?
The fix is uploaded WICED 3.1.2 Fix for FreeRTOS with LwIP
Would be really nice to integrate Doxygen in Eclipse so that people can add Doxygen tag and generate documenatation for the WICED app they write.
See
