The WICED SmartBridge™ utilizes both the BCM43362 (Wi-Fi) and BCM20702 (BT) while providing a bridge between Bluetooth Smart sensors and the internet.
This is the WICED SmartBridge Reference Design (WICED BT/BLE TO WIFI BRIDGE W/ BCM43362 AND BCM20702).
All software/docs for the SmartBridge are included in the WICED SDK:
- Libraries (both in source and libs located in Library/Bluetooth directory)
- Example applications: Apps/demo/bt_smartbridge; Apps/snip/bt_rfcomm; Apps/test/bt_smartbridge_console; and Apps/test/bt_smartbridge_mfg_test
- API documentation (Doc/API.html)
- BCM9WCDPLUS114 board schematics (Doc/schematics directory)
It should also be noted that the BCM9WCDPLUS114 SmartBridge discussed in our slides/literature is essentially the same thing as the BCM9WCD1BRIDGE_1 reference design stocked by our distributors: https://avnetexpress.avnet.com/store/em/EMController?term=Bcm9wcd1bridge_1&action=products&langId=-1...
- Wi-Fi module: WM-N-BM-14
- Bluetooth module: BM-GP-BR-65
SDK 2.4.1
SDK 3.x
SPI
Wifi+Bluetooth
Any update on BCM9WCD5EVAL1_1 SmartBridge board that uses the BCM43341?
But the BT is "regular" BT, not BT LE?
And for audio over WiFi I need a different eval board in addition?
WICED WiFi and WICED Smart (with BT LE) is not ment?
