I installed "WICED-Smart-SDK-2.2-IDE-Installer (Windows)" on my system, but when I am  trying  to run it I get an error message {Failed to load the JNI shared library "c:\programFiles\java\jdk1.6.0_45\bin\..\jre\bin\server\jvm.dll" }.I m already using eclipse with java1.6..0_45.
SeyhanA_31
You can download the Wiced Smart SDK only, WICED-Smart-SDK-2.2 (.7z Archive). without the eclipse intaller.
Unzip it to location you want.
From your already installed eclipse import the Wiced-Smart-SDK-2.2 "Import Existing Code" to your eclipse work space.
Seyhan
