I would like to integrate the WICED SDK into an ARM MCU (ATSAMV7) that is not implemented by default. Since the SDK is implemented for STM M7-Cortex, would there by obstacles that we should expect? Is there any information or advice that could be useful into integrating the SDK with the ATSAMV7?
Other Technologies General
Porting a new MCU to WICED is complex task and needs a lot of work and testing. I would recommend you look at the WHD driver. Its an independent driver that can be integrated into your tool of choice. The documentation should guide you with the porting steps and layers.
This will be much simpler and is documented better.
Winston
Winston
