I am using the Avnet IoT starterkit containing a module wth BCM4343 + STM32F411.
WICED SDK 4.1 on Windows10.
Is it possible to display the internal module registers by name in the WICED SDK debug environment (ADC, DMA etc)?
The "modules" window in the WICED SDK remains empty, while the original STM and other Eclipse tools allow module register views.
Thanks for any idea on how to implement this feature in the WICED SDK!
Klaus
Hi.
Try install eclipse plugin. Google it...
Darius
I using EmbSysRegView. It have support big number of mcu.
Try find and install it via eclipse marketplace or manually.
Darius
?how do you setup the debug configuration on eclipse for this
After install EmbSysRegView, do:
1. Windows->Preferences-> C/C++ -> Debug -> "EmbSys Register View" select MCU
2. Then at debug mode, Windows-> "Show View" -> Others -> Debug -> EmbSys Registers.
BR.
Darius
This other question. Please find wiced startup documents- maybe it can help.
WICED-SDK ->DOC -> WICED-QSG204.pdf
BR.
Darius
