pescc_1773016
First like given
I am in the process of installing WICED SDK 3.3.1. The SDK seems to install without error but when I start WICED Smart IDE I get the following error:
Tried installing other SDKs with no problems.
3.3.1 Installs but does not Run.
3.1.2 Installs and Runs.
3.1.1 Installs and Runs.
3.1.0 Installs and Runs.
2.4.1 Installs and Runs.
How do I get 3.3.1 to run properly?
MichaelF_56
scharppe
I had problems with the 3.3.1 Installer as well.
I had to use the instructions jaeyoung created here in order to get this version working.
The good thing about this method is that it streamlines running multiple versions of the SDK.
MichaelF_56
scharppe
Thanks for the info.
