Hello
I'm working on a firmware to put our WiFi/BLE transmitter in test mode for regulatory testing. According to the regulatory guide, I need to contact Cypress and obtain a .clm_blob
https://www.cypress.com/documentation/application-notes/an225347-cypress-wi-fi-clm-regulatory-manual
Can I instead integrate the wl_tool in our firmware or are there any libraries I can use?
PaBo_4310606 Are you using a module or a bare die as is? If module, please contact your module vendor, If bare die please contact local sales/marketing and they should be able to help you with the BLOB and the wl tool.
--> by this do you mean that you have the wl tool and can't load it? Are you working on linux/WICED? What is the chip under consideration?
