What could cause the system to not recognize the proper drivers?
When connecting our PCB to a laptop, I do not see WICED JTag Port or WICED USB serial port.
I only get 2 generic USB Serial Port to appear (COM3, COM4):
I tried updating them using this thread/doc. , https://community.infineon.com/t5/Resource-Library/Upgrade-USB-Drivers-for-WICED-Studio-6-1/ta-p/246... but still not getting those drivers to populate.
Hi ,
Please check again that wiced drivers are installed properly.
Rakesh B G
thank you, I was able to get my laptop to recognize the drivers.
but now I cannot connect to the Serial Port
Once I connect, I can run the scan app, which shows me all the available SSID.
I am trying to test the eval board, using the wl.. tool, but cannot connect with the com ports.
C:\xxxx\WICED-Studio-6.6\43xxx_Wi-Fi\libraries\test\wl_tool>wl43909B0.exe -- serial 9
CreateFile failed with error 2.
rwl_open_transport: Can't open serial port
serial device open error
when I build and run the app test_mfg app i get the following, which is not complete as the document shows.
Starting WICED Wiced_006.006.001.0001
Platform MurataType1GC initialised
Started ThreadX v5.9
WICED_core Initialized
Initialising NetX_Duo v5.12
Creating Packet pools
WLAN MAC Address : 58:D5:0A:B4:4F:72
WLAN Firmware : wl0: Jul 20 2020 00:11:08 version 7.15.168.149 (21d266a WLTEST) FWID 01-f4b31b56
WLAN CLM : API: 12.2 Data: 9.10.74 Compiler: 1.31.3 ClmImport: 1.36.3 Creation: 2020-07-20 00:04:25
Please try re-installing the drivers properly and check .
Rakesh B G
