We have reached a point of uploading a larger amount of DATA into the cloud - we are talking a few tens of MBytes. It seems that Azure provides support for both protocols, though MQTT seems simpler.
My question is if we should expect speed / robustness limitations with the current MQTT 3.1.1 from inside WICED and should we consider WICED AMQP 1.0 instead ?
Has anyone run this scenario of streaming data over WIFI with the current version of WICED MQTT ? What kind of upload speeds would saturate WICED MQTT 3.1.1 implemention ? -- Thanks, BM
You can go ahead with MQTT and let us know if you face any issue to upload large chunks of data to azure cloud. I had tested MQTT 3.1.1 with AWS in the past and did not see any issue (I am hoping you would not either).
