user_4051776
5 likes given First like given
We have reached a point of uploading a larger amount of DATA into the cloud - we are talking a few tens of MBytes. It seems that Azure provides support for both protocols, though MQTT seems simpler.
My question is if we should expect speed / robustness limitations with the current MQTT 3.1.1 from inside WICED and should we consider WICED AMQP 1.0 instead ?
Has anyone run this scenario of streaming data over WIFI with the current version of WICED MQTT ? What kind of upload speeds would saturate WICED MQTT 3.1.1 implemention ? -- Thanks, BM
RaktimR_11
500 replies posted 250 replies posted 100 replies posted
You can go ahead with MQTT and let us know if you face any issue to upload large chunks of data to azure cloud. I had tested MQTT 3.1.1 with AWS in the past and did not see any issue (I am hoping you would not either).
RaktimR_11
