Has anyone worked with a TPM device inside WICED environment ? We have tried to use the Infineon TPM2.0 ( SLB9670vq20 ) which seems pretty decent, but we have not found a decent driver for it except a complicated driver for Linux. We are using STM32F469 and are looking for a TPM driver for this MCU. Appreciate some feedback. -- Thanks, BM
I think this query is more related to Infineon TPM device specific. If you face any issue in porting a RTOS based SPI driver in WICED, you can raise the issue in CY community.
I am familiar only with its use in the Linux environment. You should contact your Infineon FAE to see what else is cooking.
Thank you for replying. We talked with Infineon, they gave us some initial support, but then they stopped supporting us as we are not a high volume customer. So I am trying to reach here... We could eventually write the driver for our MCU (STM32F429), but we have some issues with the SPI commands. The only command that works is: read DID_VID register, returning the correct value, but its address had a 0xD4 added to the 16-bit address and we did not understand why. Do you know the EXACT byte by byte command to read the STATUS register TPM_STS_0 and what we need to expect reading it right after power up ? That would help...
--Thaks, BM
I am sorry that I can't help with the I/O details of that part because I wasn't involved at that level. In our case, we did make headway with Infineon some years ago on a (likely different) TPM even though our volumes were going to be relatively low (in the 100's to 1000's per year). So, I would persist. You do need their support!
Thank you.. Currently we have a simpler solution, but early next year we'll restart the TPM project.
