As I am working with Smartbridge, I noticed that a call to wiced_bt_smartbridge_deinit() function makes my program crash. After few investigations, I have pointed out a bug in the sub-layers of this function.
Just to remind, here is the content of the function itself :
wiced_result_t wiced_bt_smartbridge_deinit( void )
if ( initialised == WICED_FALSE )
return WICED_BT_SUCCESS;
/* Disable Attribute Cache (The function checks if it's enabled) */
bt_smartbridge_att_cache_disable();
/* Deinitialise socket manager */
bt_smartbridge_socket_manager_deinit();
/* Deinitialise GATT */
smartbridge_bt_interface_deinitialize();
initialised = WICED_FALSE;
Then, in the call to smartbridge_bt_interface_deinitialize() :
wiced_result_t smartbridge_bt_interface_deinitialize( void )
WPRINT_LIB_INFO( ( "[SmartBridge] Deinitializing Bluetooth Interface...\n" ) );
wiced_rtos_deinit_mutex( &subprocedure.mutex );
wiced_rtos_deinit_semaphore( &subprocedure.done_semaphore );
subprocedure_reset();
We continue in subprocedure_reset() :
wiced_result_t subprocedure_reset( void )
subprocedure.subprocedure = GATT_SUBPROCEDURE_NONE;
subprocedure.attr_head = NULL;
subprocedure.attr_tail = NULL;
subprocedure.attr_count = 0;
subprocedure.result = WICED_BT_SUCCESS;
subprocedure.start_handle = 0;
subprocedure.end_handle = 0;
//subprocedure.pdu = 0;
subprocedure.length = 0;
subprocedure.offset = 0;
subprocedure.connection_handle = 0;
memset( &subprocedure.uuid, 0, sizeof( subprocedure.uuid ) );
subprocedure_wait_clear_semaphore();
And finally in subprocedure_wait_for_completion() :
wiced_result_t subprocedure_wait_clear_semaphore( void )
while ( wiced_rtos_get_semaphore( &subprocedure.done_semaphore, WICED_NO_WAIT ) == WICED_BT_SUCCESS )
So, the problem is in smartbridge_bt_interface_deinitialize() function, in which there is a call to subprocedure_reset() which manipulates the semaphore after a call to wiced_rtos_deinit_semaphore( &subprocedure.done_semaphore ) which removes the semaphore itself.
So the solution I found simply consists in switching those two calls :
I just wanted to expose this so you can take it into consideration for next releases.
SDK 3.x
Wifi+Bluetooth
Thanks for the feedback romain
I went ahead a created a bug tracking request internally so that the SW team could review and consider this fix for the next release of the SDK.
No, the latest sdk does not fix this.
