Wi-Fi Combo Forum Discussions
I need to test WICED Wi-Fi 3.3.1 restful smart server demo. But I can't find any explanation or any doc regarding that.
Can I have explanation regarding how to test demo ?
Thanks.mwf_mmfaeseyhangangi
JaeyoungY_71
Hi rajvirzala,
The RESTful Smart server is the successor of SmartBridge. You can issue http get/put requests to the WICED boards to get them to scan/connect/read and write characteristic and descriptor values from ble peripherals. Below is a guide on how to use the RESTful Smart Server. You can use either curl commands if you have Cygwin installed, or RESTful clients for a gui environment. This will work on 43909 / 43341 / 43438 chips.
REST Client For Mac
https://luckymarmot.com/paw
REST Client For Windows
http://restclientgui.codeplex.com/
Also attached are the GAP and GATT API spec sheets.
Jaeyoung
JaeyoungY_71
Hi rajvirzala,
REST Client For Mac
Jaeyoung
