Dear.
in WICED 2.4.1
P2P and Phone connected
but not disconnected event
P2P and Phone Do not re-connect
I should Updated to WICED 3.1.0 from WICED 2.4.1
Our final goal is WICED 3.1.1
I used is BCM9WCDUSI09 platform
WICED 3.1.0 does not BCM9WCDUSI09 platfororm
we want to use is:
(WICED 3.1.0) test.console-BCM9WCDUSI09 download run
1) why not BCM9WCDUSI09 platfororm ?
2) We will be sure to use the p2p. Please inform us if any suggestions ?
Thanks for the support.
SDK 2.4.1
SDK 3.x
Wi-Fi Direct
I would like to clarify above cgkim's question here.
We are using WICED SDK 2.4.1 with USI BM-09 module but there are a lot of problem with P2P function as explained above(no disconnet event).
We heard that WICED SDK 3.1.1 will fix this issue and have more enhancements for WiFi direct function.
But since SDK 3.0.1 there is no USI BM-09 platform. So here is our question.
1. Does WICED SDK 3.1.1 support USI BM-09 platform?
2. If not support, can we extract P2P code from SDK 3.1.1 and merge into SDK 2.4.1? If we can, would you please explain how?
Please let me konw if you have any question on this.
Appreciate your support.
Moon
Hi Moonsik,
To repeat Yes
2. If not support, can we extract P2P code from SDK 3.1.1 and merge into SDK 2.4.1? If we can, would you please explain how? Yes it can be done by copying certain files of p2p related code 3.1.1 and port it to 2.4.1. But would suggest using 3.1.1 api and have platform files for USI BM-09 platform imported into SDK 3.1.1( since SDK 3.0.1 there is no USI BM-09 platform)
thnx
vik86
in WICED 2.4.1
Assume this would be fixed in 3.1.1 release
Refer to this blog:
we want to use is:
1) why not BCM9WCDUSI09 platfororm ? since SDK 3.0.1 there is no USI BM-09 platform
2) We will be sure to use the p2p. Please inform us if any suggestions ? Yes p2p with more api support would be implemented in 3.1.1 nikvh
thnx
vik86
