Wi-Fi Combo Forum Discussions
GiHe_2512991
Hello all using cyw94343,  cypress has only 2 PWM cpio's assigned with this model,   I need to create a total of 4 - 6 to control motors, driven off this
device.   Which libraries do   i need to add to or duplicate from give me a total 4 or 6 assignment's of  GPIO's to test this with. This being software driven are
their specific physical  restrictions in re-using the existing non pwm GPIO's, and re-assigning them to PWM GPIO actions, it should be a library assignment and header .h
creation or  duplication issue ??
Let me know if i'm off track here    thanks ahead of time to y'all.
PriyaM_16
25 solutions authored 10 solutions authored 5 solutions authored
You can use the WICED peripheral alias given in platform.c file of your platform.
The struct platform_pwm_peripherals[] contains configurations for different aliases provided by WICED. You can use the GPIOs mentioned in the struct as PWMs.
PriyaM_16
