Wi-Fi Combo Forum Discussions
I am using SN8200x Murata wifi module and WICED SDK-2.4.0. I need to use the watchdog timer which I assume is present in STM32 controller itself. Are there any APIs in WICED SDK for using watchdog timer ?
SeyhanA_31
Please take a look at ...Wiced/Platform/common/ARM-Cortex_xx/.../watchdog.h&c and expand it as you wish.
Hope it helps.
SeyhanA_31
Hope it helps.
The watchdog functionality is enabled by default in the WICED-SDK and is automatically kicked (or patted) by the system_monitor thread. The system_monitor can be used to perform finer grained analysis of parts of the system to ensure individual threads or resources are not in a locked state.
Thank you.
