I'm using CYW43907 eval kit with WICED SDK 6.2.1. I am porting a C based networking application to WICED SDK (FreeRTOS + LWIP) and it uses TCP client-server model for inter-thread communication. My issue is, the "wiced_tcp_connect" API always returns error and communication is not established between the threads. The same threads are able to connect to remote server/client respectively but not to each other. Is there any limitation in WICED SDK (FreeRTOS + LWIP) that does not allow socket connections between threads of same application?
I am not sure whether this is doable in existing wiced tcpip framework. Currently the library is like application->wiced_framework --> BESL/mbedTLS --> network layer but I think you are looking at it more like pplication->wiced_framework --> BESL/mbedTLS -->network --> BESL/mbedTLS --> wiced framework --> application which is not available at this moment. Kindly share a stripped down version of your application to help us understand the scenario better. If that's not an option, please check the error code you are receiving and then try to start debugging from that.
