MiRo_263836
100 replies posted 50 likes received 50 replies posted
This is the 1st time that I am using FreeRTOS in WICED (on an STM32F429) and I want to make sure that I am initializing tasks in the best place.  I did it right after wiced_init() in the application start.
void application_start( )
    wiced_init( );
    TaskConfigID_handle = xTaskCreateStatic( TaskConfigID, "AssignID", CONFIG_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), ConfigIDStack, &ConfigID_buffer );
    TaskICM20948_handle = xTaskCreateStatic( TaskICM20948, "IMU", IMU_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), ICM20948Stack, &ICM20948_buffer );
    TaskBQ27411_handle  = xTaskCreateStatic( TaskBQ27411, "FuelGauge", BAT_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), BQ28411Stack, &BQ27411_buffer );
    TaskUI_handle       = xTaskCreateStatic( TaskUI, "UserLED", UI_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), UIStack, &UI_buffer );
    TaskSFlash_handle   = xTaskCreateStatic( TaskSFlash, "SFlash", SFLASH_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), SFlashStack, &SFlash_buffer );
    TaskDebug_handle    = xTaskCreateStatic( TaskDebug, "Debug", DEBUG_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), DebugStack, &Debug_buffer );
    TaskUSB_HS_handle   = xTaskCreateStatic( TaskUSB, "USB_HS",USB_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), USB_HS_Stack, &USB_HS_buffer );
    TaskWIFI_handle     = xTaskCreateStatic( TaskWIFI, "WIFI", WIFI_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), WIFIStack, &WIFI_buffer );
    TaskBlue_handle     = xTaskCreateStatic( TaskWIFI, "Blue", BLUE_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), BlueStack, &Blue_buffer );
    TaskRTC_handle      = xTaskCreateStatic( TaskWIFI, "RTC", RTC_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), RTCStack, &RTC_buffer );
    TaskOTA_handle      = xTaskCreateStatic( TaskWIFI, "OTA", OTA_TASK_STACK_SIZE, NULL, WICED_PRIORITY_TO_NATIVE_PRIORITY(WICED_APPLICATION_PRIORITY), OTAStack, &OTA_buffer );
Yeshwanth_KT
50 replies posted 25 replies posted 10 likes received
Hello mroberts_arrow
Yes, the correct place to initialize tasks is after wiced_init(). This will make sure that all the required peripherals are initialized before any thread starts.
You can also go through this RTOS tutorial series for more information and learning - https://www.cypress.com/training/wiced-wi-fi-101-chapter-3-wiced-rtos-features
Yeshwanth
Yeshwanth_KT
Yeshwanth
