Wi-Fi Combo Forum Discussions
AbBa_4336446
10 replies posted 5 replies posted 5 questions asked
Hello.
The Bluetooth Internet Gateway code example mentions that it supports CY8CKIT-062S2-43012 featuring CYW43012 radio (GitHub - cypresssemiconductorco/mbed-os-example-bluetooth-mesh-gateway: This code example demonstrat... )
is it possible to use the above code example with CY8CPROTO-062-4343W featuring the CY4343W radio? since both radios support BLE mesh (43012 support B5 while 4343w support B4.1)
what do I need to modify in code example in these cases?
Karim
DheerajPK_41
"Mesh Gateway" is a customized mesh application developed to run on 43012. No other platforms are supported.
The libraries such as bluetooth-gateway.lib is also supported only in 43012.
-Dheeraj
DheerajPK_41
-Dheeraj
I would like to add an information.
Our software team is working on extending the support of Mesh Gateway functionality to PSoC6+4343W platform as well. Hopefully it will available to the customers later this year.
-Dheeraj
Thanks for the info. Waiting the updates.
Karim
