Wi-Fi Combo
hollylu
New Contributor
I tried to work on the EWD_Sterling evaluation board, and I want to start from the introducer, but I don't know how to install the ios demo app on my ipad.  The step by step only shows the app (wifiintroduce)location, but it didn't tell how to install it, does any one can help? I never install things to ipad from PC.  Thank you.
Holly
Charles_Lai
It's not the final application file. It's the source code that can be opened in Xcode.
You have to open the project and then build and run it in Xcode. Because normally a third-party application file cannot be directly installed on an iOS device.
Charles_Lai
