Jul 26, 2022
07:11 PM
Jul 26, 2022
07:11 PM
1GC sends data using UDP, Call wiced_result_t wiced_udp_send(wiced_udp_socket_t * socket, const wiced_ip_address_t * address, uint16_t port, wiced_packet_t * packet), can only send 1472 bytes?
I have changed NX_DONT_FRAGMENT to NX_FRAGMENT_OKAY when I call wiced_UDP_create_socket to create UDP socket. The result is also not supported.
Call wiced_packet_create_udp(socket, 4000, &packet, (uint8_t**) &data, &available_data_length), The value of available_data_length is 1508.
11:14 PM
Jul 26, 2022
11:14 PM
hello:
would you please tell me which version of the WICED is used now? thanks.
