04:30 AM
Aug 05, 2016
04:30 AM
Hello All,
We are working on wiced sdk 3.5.2. we are facing the problem of the udp packet send fail every time.
sometime it work fine but i didn't understand what is the problem.
need help ....
Labels
SDK 3.x
Wi-Fi Direct
Aug 07, 2016
01:56 AM
Aug 07, 2016
01:56 AM
My test with snip.udp_transmit looks fine.
You should double check with the snip code to verify if it's sdk issue or other issues in your own code.
Aug 07, 2016
04:55 AM
Aug 07, 2016
04:55 AM
Aug 09, 2016
06:14 PM
Aug 09, 2016
06:14 PM
bharanee wrote:
I'm having similar issues, see reproducible test case in UDP packet pool starvation with NetX_Duo
Well, I tested on FreeRTOS+LwIP build only. I don't use NetX_Duo.
08:48 PM
Aug 11, 2016
08:48 PM
Thanks for valuable responce,
I test with snip.config but it not able to configure wifi module with router,
uninstalling the Wiced 3.5.2 and reinstall then download and run my code , it is working fine. also the snip.config working well.
