SDK - 2.4.1 mcu-stm32f407ig chip-bcm43362
Im trying to stream 80x80 50Hz camera image frames through wifi direct + udp.
In this UDP packet creation fails often in between.
What should I do?
Increase Heap Size?
Increase Networking Worker Thread Stack Size?
Increase Application Thread Stack Size?
Increase  TX_PACKET_POOL_SIZE?
Is there any other things I should try?
Thanks and Regards,
Sooraj
SeyhanA_31
250 replies posted 100 replies posted 50 replies posted
How the UDP packet creation fails? What is the return value?
How long are you waiting for the packet creation?
How many packet and bytes per packet are you creating?
Seyhan
Discussion is being locked. If you have any follow-up questions, please start a new discussion.
