Wi-Fi Combo Forum Discussions
If I want  to  use WICED_UART_2, which pins on the ST micro would this map to?
I'm using the ISM43362_M3G_L44 module.
Never mind I found it in the platform.c fie:
[WICED_UART_2] =
  .port = USART3,
  .tx_pin = &platform_gpio_pins[WICED_GPIO_19],
  .rx_pin = &platform_gpio_pins[WICED_GPIO_20],
  .cts_pin = &platform_gpio_pins[WICED_GPIO_21],
  .rts_pin = &platform_gpio_pins[WICED_GPIO_22],
  .tx_dma_config =
  .controller = DMA1,
  .stream = DMA1_Stream4,
  .channel = DMA_Channel_7,
  .irq_vector = DMA1_Stream4_IRQn,
  .complete_flags = DMA_HISR_TCIF4,
  .error_flags = ( DMA_HISR_TEIF4 | DMA_HISR_FEIF4 | DMA_HISR_DMEIF4 ),
  .rx_dma_config =
  .controller = DMA1,
  .stream = DMA1_Stream1,
  .channel = DMA_Channel_4,
  .irq_vector = DMA1_Stream1_IRQn,
  .complete_flags = DMA_LISR_TCIF1,
  .error_flags = ( DMA_LISR_TEIF1 | DMA_LISR_FEIF1 | DMA_LISR_DMEIF1 ),
[WICED_UART_2] =
  .port = USART3,
  .tx_dma_config =
  .controller = DMA1,
  .rx_dma_config =
  .controller = DMA1,
