Wi-Fi Combo Forum Discussions
I am working on inventek ISM43340/41 evaluation board which has STM32F4XX controller with BCM43340/41 broadcom chip.
I need information about which third party programmer supports WICED IDE. Also is there any production tool developed by broadcom
for production programming like SmartRF flash programmer developed by TI?
I believe .bin & .elf files build using WICED can be be flashed in STM32F4XX controller using third party programmer. Still question remains is how to flash .dct file using third party tools ?
Reply ASAP
mwf_mmfaedickbseyhanseyhangangivsesto@
Hi all,
can I get response ASAP, because I need this info for production
I will ask one of the AEs for WICED to respond.
I do not have in depth knowledge about WICED's support for third party programmers myself.
you can do all this using JTAG and openocd (that's how WICED do with the download rule).
You can use the same openocd commands/config file for production if you have the possibility to connect JTAG pins.
