Does the TLS implementation in SDK 3.5.2 supports SNI?
Baris
SNI support is included in SDK-3.6.3.
If you want to test it, you might want to contact mwf_mmfae​ to get access for it.
SeyhanA_31
250 replies posted 100 replies posted 50 replies posted
Hi Baris,
We are looking into this.
Seyhan
seyhan wrote:
Hi Baris,
Seyhan
Hi seyhan​,
Any progress on supporting SNI?
Some https servers disconnect immediately after client sent hello if client does not send SNI.
This is presently being implemented, hope we have this released soon.
Would you backport this for older SDK?
We stuck at SDK-3.1.2 due to OTA issue.
(Sigh, new SDK should always compatible with older SDK!)
The fact is missing SNI can cause connect server failure, which is a bug needs fix.
Or anyone we can contact to get a backport for SNI feature for SDK-3.1.2?
Any idea when the SNI update will be released? We also need SNI because AWS API gateway drops anything without SNI immediately.
Awesome thanks. Have sent them a message.
