Please help me with this issue, I am trying to enable the renegotiation support in mbedtls. It seems like the code for this path is not working, it is not even building right. However, I tried to debug the code and make it build correctly, but unfortunately the renegotiation didnt work well.
Thank you
Can you please let me know if you have enabled MBEDTLS_SSL_RENEGOTIATION macro in your setup for renegotiation.
Can you please let me know if you need any help on this.
As mentioned earlier, please enable MBEDTLS_SSL_RENEGOTIATION macro in your configuration and also make ensure that your server supports renegotiation.
