Hello !
I have problem when starting a https server in softAP mode. The error obtained is TLS connection error. I do not have a TLS server, I use the brcm certificate using "USE_SELF_SIGNED_TLS_CERT". Is there any application example showing the usage of wiced_https_server_start/stop ?
The SDK used is 2.4.1, can I have access to the 3.x SDK?
Thank you !
Security
Web Services
Do you have same issue if HTTPS server is run on 443? I doubt there is a difference, but technically this is where it should be run.
TLS1.2 support is in next version of SDK.I'll look into your other requests.
Would it be possible to provide an application snippet that can duplicate this issue?
Hello gangi,
I still have the same problem "Error starting TLS connection" even with the SDK 3.0.
here is a snippet of the code used :
void application_start() {
wiced_init( );
wiced_network_up(WICED_AP_INTERFACE, WICED_USE_INTERNAL_DHCP_SERVER, &ap_ip_settings);
wiced_https_server_start( &ap_http_server, 80, appliance_web_pages, NULL, NULL, WICED_AP_INTERFACE );
Hello gangi,
The port 443 solved the problem. Thank you for your help
