aloncatz
5 replies posted 10 sign-ins 5 sign-ins
I'm trying to enable CDC ECM in CYW954907AEVAL1F. I found this answer from 2018 that it's not supported. Is it still the case? If it's supported, can you point me to an example?
Solved: How to enable the USB CDC ECM in WICED - Page 2 - Infineon Developer Community
Rakesh_BG
50 solutions authored 100 replies posted 100 sign-ins
You can use latest release of modus tool box .
Rakesh B G
Rakesh_BG
wiced is not recommended for newer designs.
There are new improvements released later to wiced v6.2. So it won’t be having the support for ECM.
 Rakesh B G
aloncatz
What is recommended for newer designs instead of Wiced?
Rakesh_BG
Rakesh B G
