Wi-Fi Combo Forum Discussions
When I use Snip.websocket_client without modification  (SDK 5.0), I have :
Connecting to server...
Trying to connect<\r><\n>
Not a valid IP address?? Trying hostname lookup...<\r><\n>
Error number received = 1<\r><\r><\n>
[websocket_tls_connect] Error[5035] connecting @websocket: 0x200014bc<\r><\n>
When I deseable TLS (comment the line #define USE_WEBSOCKET_SECURE_CLIENT), It work perfectly.
Have you some idea
B.R.
Ludo
Use below certificate string in websocket_client.c instead of the old ones. Check if it works.
    "-----BEGIN CERTIFICATE-----\n"                                      \
    "MIIEfTCCA2WgAwIBAgIDG+cVMA0GCSqGSIb3DQEBCwUAMGMxCzAJBgNVBAYTAlVT\n" \
    "MSEwHwYDVQQKExhUaGUgR28gRGFkZHkgR3JvdXAsIEluYy4xMTAvBgNVBAsTKEdv\n" \
    "IERhZGR5IENsYXNzIDIgQ2VydGlmaWNhdGlvbiBBdXRob3JpdHkwHhcNMTQwMTAx\n" \
    "MDcwMDAwWhcNMzEwNTMwMDcwMDAwWjCBgzELMAkGA1UEBhMCVVMxEDAOBgNVBAgT\n" \
    "B0FyaXpvbmExEzARBgNVBAcTClNjb3R0c2RhbGUxGjAYBgNVBAoTEUdvRGFkZHku\n" \
    "Y29tLCBJbmMuMTEwLwYDVQQDEyhHbyBEYWRkeSBSb290IENlcnRpZmljYXRlIEF1\n" \
    "dGhvcml0eSAtIEcyMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAv3Fi\n" \
    "CPH6WTT3G8kYo/eASVjpIoMTpsUgQwE7hPHmhUmfJ+r2hBtOoLTbcJjHMgGxBT4H\n" \
    "Tu70+k8vWTAi56sZVmvigAf88xZ1gDlRe+X5NbZ0TqmNghPktj+pA4P6or6KFWp/\n" \
    "3gvDthkUBcrqw6gElDtGfDIN8wBmIsiNaW02jBEYt9OyHGC0OPoCjM7T3UYH3go+\n" \
    "6118yHz7sCtTpJJiaVElBWEaRIGMLKlDliPfrDqBmg4pxRyp6V0etp6eMAo5zvGI\n" \
    "gPtLXcwy7IViQyU0AlYnAZG0O3AqP26x6JyIAX2f1PnbU21gnb8s51iruF9G/M7E\n" \
    "GwM8CetJMVxpRrPgRwIDAQABo4IBFzCCARMwDwYDVR0TAQH/BAUwAwEB/zAOBgNV\n" \
    "HQ8BAf8EBAMCAQYwHQYDVR0OBBYEFDqahQcQZyi27/a9BUFuIMGU2g/eMB8GA1Ud\n" \
    "IwQYMBaAFNLEsNKR1EwRcbNhyz2h/t2oatTjMDQGCCsGAQUFBwEBBCgwJjAkBggr\n" \
    "BgEFBQcwAYYYaHR0cDovL29jc3AuZ29kYWRkeS5jb20vMDIGA1UdHwQrMCkwJ6Al\n" \
    "oCOGIWh0dHA6Ly9jcmwuZ29kYWRkeS5jb20vZ2Ryb290LmNybDBGBgNVHSAEPzA9\n" \
    "MDsGBFUdIAAwMzAxBggrBgEFBQcCARYlaHR0cHM6Ly9jZXJ0cy5nb2RhZGR5LmNv\n" \
    "bS9yZXBvc2l0b3J5LzANBgkqhkiG9w0BAQsFAAOCAQEAWQtTvZKGEacke+1bMc8d\n" \
    "H2xwxbhuvk679r6XUOEwf7ooXGKUwuN+M/f7QnaF25UcjCJYdQkMiGVnOQoWCcWg\n" \
    "OJekxSOTP7QYpgEGRJHjp2kntFolfzq3Ms3dhP8qOCkzpN1nsoX+oYggHFCJyNwq\n" \
    "9kIDN0zmiN/VryTyscPfzLXs4Jlet0lUIDyUGAzHHFIYSaRt4bNYC8nY7NmuHDKO\n" \
    "KHAN4v6mF56ED71XcLNa6R+ghlO773z/aQvgSMO3kwvIClTErF0UZzdsyqUvMQg3\n" \
    "qm5vjLyb4lddJIGvl5echK1srDdMZvNhkREg5L4wn3qkKQmw4TRfZHcYQFHfjDCm\n" \
    "rw==\n"                                                             \
    "-----END CERTIFICATE-----\n"                                        \
DaBa_2244756
25 likes received 10 likes received 10 likes given
Hi.
How much you sent / receive?
Possible this problem was reported at previous week...
If receive small packet < 1400 then tls working.
BR.
Darius
Hi Darius,
The problem doesn't depend of data size, it's only during the connexion.
at this time, I haven't sent anything
B.R.
Ludo
Do you could establish SSL connect to your server with WICED https_client ?
Hi
When I use the https exemple, I have
waiting for HTTP reply<\r><\n>
[I - APP     ] Server returned<\r><\n>
HTTP/1.1 302 Found<\r><\r><\n>
Cache-Control: private<\r><\r><\n>
Content-Type: text/html; charset=UTF-8<\r><\r><\n>
Referrer-Policy: no-referrer<\r><\r><\n>
Location: https://www.google.fr/?gfe_rd=cr&ei=Y7uKWcmtB6_c8AeBk4GIDg<\r><\r><\n>
Content-Length: 259<\r><\r><\n>
Date: Wed, 09 Aug 2017 07:36:03 GMT<\r><\r><\n>
Alt-Svc: quic=":443"; ma=2592000; v="39,38,37,36,35"<\r><\r><\n>
Connection: close<\r><\r><\n>
<\r><\r><\n>
<HTML><HEAD><meta http-equiv="content-type" content="text/html;charset=utf-8"><\r><\n>
<TITLE>302 Moved</TITLE></HEAD><BODY><\r><\n>
<H1>302 Moved</H1><\r>
It seem be good with this exemple.
JoYi_1844281
Level 6
Level 6
100 sign-ins 100 replies posted 50 likes received
You should modified the code to connect your web socket server
First to verified the SSL established is ok or not ?
As you mention the web socket could success exchange without TLS!
If the https client example could not establish connection to your web socket server!
The problem is TLS , not web socket !
Are you trying the default websocket_client application?
If so, TLS connection to echo.websocket.org may fail because of wrong/old root certificate.
Try with the latest root-certificate published by echo.websocket.org and it should work.
I have download the certificate :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Can you confirm that is the good one ?
With this one, I have the same probleme.
If TLS is enable : failed
[I - APP     ] <\r><\r><\n>
without TLS it works perfectly
Ludo
The certificate which I've is different from what you posted here. Can you confirm that you're using the root CA certificate from GoDaddy as required by echo.websocket.org ?
    "rw==\n"                                                             \
Thanks It works perfectly with your certificate.
When I was taking the certificate, I wasn't take the good one (Root)
thank you
Ludo
