Would please help me to set up the mqtt server ?
Where do I start?
AndrewY_86
25 sign-ins 25 replies posted 10 replies posted
I see that you categorized this under AWS, so assuming that this is what you want to use, the following link would be a good resource to get started: http://docs.aws.amazon.com/iot/latest/developerguide/iot-gs.html
You can find demo applications using MQTT on AWS at <WICED_SDK>/apps/demo/aws_iot
AxLi_1746341
Level 7
Level 7
10 comments on KBA 5 comments on KBA First comment on KBA
