Wi-Fi Combo Forum Discussions
I am working on porting the WiFi driver for Murata 1DX on a custom board using the reference from WICED SDK.
Currently I am trying to Join an AP with "WICED_SECURITY_WPA2_MIXED_PSK" Security. But the wwd_wifi_join() API always fails with WWD_WLAN_UNSUPPORTED response.
I am able to Join the same AP with Open Security.
When i furthure debugged it I came to know that the error comes when I try to sets the current EAPOL key timeout for STA Interface.
Can anyone tell me what are the possible cases in which this error may arise?
Thank you in advance.
I am able to solve the issue. I guess the issue is regarding the Firmware provided by Murata on their Github for 1DX. Maybe it doesn't support the EAPOL variable setting commands. I used the firmware provided by WICED SDK and now it works fine.
1) FW - WICED SDK
2) NVRAM Image for 1DX - Murata Github
3) CLM Blob Image - WICED SDK
AxLi_1746341
Level 7
Level 7
10 comments on KBA 5 comments on KBA First comment on KBA
Which sdk version are you using?
Hi axel.lin,
I am using Version 6.2
Debugging furthur I came to know that the setting of Supplicant Variable using "bsscfg: sup_wpa" fails with WWD_WLAN_UNSUPPORTED.
Is there any reason for this to fail?
Any help would be appreciated.
Thank you.
GauravS_31
250 solutions authored 250 sign-ins First comment on KBA
It appears that the IOVAR IOVAR_STR_SUP_WPA_TMO is unsupported in the firmware but I will check and confirm. We need to understand how the Wi-Fi join happens in your setup. Did you use join command from console or directly used the wwd_wifi_join() function?
I have directly used the wwd_wifi_join() api in my code.
I have used the firmware available for 1DX on Murata github repository. Is it possible that firmware does not support IOVAR_STR_SUP_WPA_TMO command?
GauravS_31
You can consider using the higher level API wiced_network_up() instead of low level WWD function to join to the AP. This will pick up the AP details from the DCT and join to the AP.
I don't get your point.
How can the higher level API wiced_network_up() avoid WWD_WLAN_UNSUPPORTED issue?
1) FW - WICED SDK
