How to use the 2Mb of SRAM in CYW43907 application?
I want to store data in SRAM and send later via SPI.
Thanks and Regards,
Sapan Shah
- cyw43907
43xxx_Wi-Fi\apps\snip\secure_mqtt\secure_mqtt.c
void application_start( void )
static wiced_mqtt_object_t mqtt_object;
wiced_result_t ret = WICED_SUCCESS;
uint32_t size_out;
wiced_init( );
/* Read root CA certificate (self certified) from resources*/
resource_get_readonly_buffer( &resources_apps_DIR_secure_mqtt_DIR_secure_mqtt_root_cacert_cer, 0, MQTT_MAX_RESOURCE_SIZE, &size_out, (const void **) &security.ca_cert );
security.ca_cert_len = size_out;
/* Memory allocated for mqtt object*/
mqtt_object = (wiced_mqtt_object_t) malloc( WICED_MQTT_OBJECT_MEMORY_SIZE_REQUIREMENT );
if ( mqtt_object == NULL )
hello:
Are you using wiced for debugg ? if so, try to use malloc function.
rate_str = malloc(rate_str_len); | |
if (rate_str == NULL) { | |
WPRINT_APP_ERROR( ( "%s: malloc failure for rate string buffer.\n", fn_name ) ); | |
return ERR_OUT_OF_HEAP; | |
I am using malloc but malloc is giving hard fault.
hello:
We should have a lot of examples in the code release , you can take them as a reference.
Can you please share path or name of example?
Thanks and Regards,
Sapan Shah
uint32_t size_out;
wiced_init( );
