Can someone please confirm that 3.5.2 has an error in the SNTP code in sntp_get_time(...) (libraries/protocols/SNTP/sntp.c:113)? Here, sntp_get_time(...) calls wiced_packet_create_udp( &socket, ...) , but socket is uninitialized (just random stack data). The LwIP code (WICED/network/LwIP/WICED/tcpip.c:664) checks the socket->dtls_context against NULL and dereferences socket->dtls_context (see tcpip.c:669), causing a hard fault.
I saw a similar (but more subtle) error in libraries/protocols/HTTP/http.c:60 in wiced_http_get(...). socket is initialized by wiced_create_socket(...), but wiced_create_socket(...) (WICED/network/LwIP/WICED/tcpip.c:254) does not zero out the structure memory. In fact, it leaves socket->tls_context as a pointer to whatever random data the stack had previously. So the wiced_tcp_connect(&socket, ...) call (http.c:64) fails at when the socket->tls_context is accessed through wiced_tcp_start_tls(socket) call inside wiced_tcp_connect(...) (tcpip.c:1034).
As a user of the API, I expect wiced_create_socket(...) to fully initialize the socket structure to default (ie, non-TLS) operation. Only wiced_enable_tls(&socket) should modify the socket->tls_context variable and change it to a non-NULL value.-- right? I found I can fix the wiced_http_get(...) function and pull it into my application by adding a memset(&socket, 0, sizeof(socket)) call before wiced_create_socket(...).
Most of my ported code works in spite of these issues. But I'm guessing that is because in my application, most connections come from a global .bss memory space and are initialized to zero by libc.
I can fix these problems in the SDK, but I'm concerned about making too many modifications to code outside of my /apps/..., as the code will get clobbered by changes in future SDK versions.
Comments/confirmation of these errors would be appreciated. Or (if unconfirmed), just tell me how to get SNTP working reliably. Thanks!
I think had better to add
memset(socket, 0, sizeof(*socket));
in the begin of wiced_tcp_create_socket() implementation.
So you don't need to add memset to all users of wiced_tcp_create_socket().
Yes. This is correct. SNTP is broken there and this has been fixed in the next rev of the SDK to be released - 3.6.2
Thanks for the quick response. I can bring it internal to my application and fix for now. When do you expect 3.6.2 will be released? Is 3.5.2 the latest to be working with?
/* Create the query packet */
memset( &socket, 0, sizeof(wiced_udp_socket_t));
result = wiced_packet_create_udp( &socket, sizeof(ntp_packet_t), &packet, (uint8_t**) &data, &available_data_length );
if ( ( result != WICED_SUCCESS ) || ( available_data_length < sizeof(ntp_packet_t) ) )
return WICED_ERROR;
Hi nsankar
As this bug causes a hard fault.
Is it possible to post a patch to the forum ASAP since you already have a fix.
So users don't have to wail until next release?
There is no socket created here
This fix is specific for the SNTP implementation
Your fix is for SNTP implementation.
But Do you see dpruessner's original post:
PS. My previous post includes the related quote.
Sorry for some reason it did not show up in my browser
Yes that will be fixed as well
That fix is already in there for NetX and NetX_Duo but was missed for LWIP
