SDK Build error while compiling with some eval boards.
I tried to test a release of the WICED SDK. But build error occurred while compiling the SDK. I attached error log, could you let me know why this happened to?
Error: unable to open ftdi device: ftdi_usb_reset failed
Runtime Error: apps/waf/sflash_write/sflash_write.tcl:124:
Makefile:183: recipe for target main_app failed
in procedure sflash_write_file
in procedure sflash_init called at file "apps/waf/sflash_write/sflash_write.tcl", line 219
in procedure init called at file "apps/waf/sflash_write/sflash_write.tcl", line 124
make.exe[1]: *** [download_dct] Error 1
make: *** [main_app] Error 2
Solution: Check USB cable if it resolves the issue. This error could be caused by a bad USB cable. Weve had some cases logged where simply changing the USB cable resolved the issue.
WICED-SDK 3.0? Where can I get this latest version?
HI Jin,
SDK 3.0 will be released soon. We will update everybody on this site.
Thank you.
Is there any release notes for SDK 3.0 final release?
What are you looking for in particular?
The current plan is to release SDK 3.0.0 at the end of the month.
The release time is good news. I'm wondering what is fixed and what it adds...and may be what it broke?
