Test on 4343W & 43438:
Below settings was working on SDK-5.1 and previous sdk versions, but it no longer work now.
# Set the WIFI firmware in multi application file system to point to firmware
ifeq ($(NO_WIFI_FIRMWARE),)
MULTI_APP_WIFI_FIRMWARE := resources/firmware/$(WLAN_CHIP)/$(WLAN_CHIP)$(WLAN_CHIP_REVISION)$(WLAN_CHIP_BIN_TYPE).bin
endif
ifeq ($(MULTI_APP_WIFI_FIRMWARE),)
ifeq ($(BUS),SDIO)
GLOBAL_DEFINES += WWD_DIRECT_RESOURCES
endif
else
# Setting some internal build parameters
WIFI_FIRMWARE := $(MULTI_APP_WIFI_FIRMWARE)
WIFI_FIRMWARE_LOCATION := WIFI_FIRMWARE_IN_MULTI_APP
GLOBAL_DEFINES += WIFI_FIRMWARE_IN_MULTI_APP
endif
Wifi+Bluetooth
Please refer to this thread WICED Studio 5.2.0 has been released....(CLM download feature breaks compatibility)
If you are using 4343X/43364/4390X then WIFI_FIRMWARE and WIFI_FIRMWARE_CLM_BLOB are now included into resources, i.e.., in WICEDFS. So you need to include
RESOURCES_LOCATION ?= RESOURCES_IN_WICEDFS
in you platform .mk file instead of the above code.
Putting WIFI_FIRMWARE and WIFI_FIRMWARE_CLM_BLOB in resources is a big mistake.
The problem is if the resource is damanged, the device is dead (no wifi function).
In our case, the resource can be OTA so the resource damage can happen.
I think cypress needs to allow disable CLM blob download as an build option.
So People can select to enable CLM blob download or not.
Or make CLM blob download optional, so if CLM blob file missed, it still work.
I'm waiting for grsr's response about this issue.
