I've installed from scratch Wiced Studio 6.2 using an administrative account on a folder accesible to all users on Windows 10. All works as expected on this account, but when I switch to an user account, although I can execute the IDE, compilations fails showing the arm-none-eabi-gcc.exe compiler was unabled to create a file on the c:\windows folder.
It doesn't matter the value assigned to the environment variables tmp, tempdir or temp, compiler always try to use C:\windows.
Is there any workaround to run Wiced on a windows user account? Issue is very easy to reproduce just switching users.
WICED Studio
Windows
Hi mifo
I'm wondering if Modus 1.0 will fix such issue?
Adding mdl from the Modus team.
Hi Axel, I have the same issue:
I have installed Wiced Studio 6.1 on my user account folder using admin rights. I can run it only from the admin account because when I try to compile form my user account it fails, it shows this message:(Unhandled win32 exception arm-none-eabi-gcc.exe).
Is not there any workaround yet ?
Hi Axel,
This is the feedback from the Dev Team:
“There is currently no workaround available to fix this issue. I have passed this feedback to internal development team so that we can fix this in our next generation IDE Modus.”
Unfortunately we cannot offer a solution for this right now, but we will address this in future releases.
Adding the applications team so they can shed some light on the issue: AnjanaM_61 GauravS_31 GyanC_36 PriyaM_16 RaktimR_11 SheetalJ_96winstonf_61
