05:23 AM
Sep 17, 2016
05:23 AM
Hi
I am using UBUNTU 14.04 32 bit
This is my c code
#include "stdio.h"
int main()
printf("hiii\n");
i tried to run this in terminal using
with gcc tool chain this is working fine, what could be the issue ??
Labels
ispn:40226:0.998:0
l1:314:0.998:0
Sep 17, 2016
07:04 PM
Sep 17, 2016
07:04 PM
#include <stdio.h> rather than #include "stdio.h".
Sep 18, 2016
08:55 PM
Sep 18, 2016
08:55 PM
Hi
Thank you for your reply , i tried both ("stdio" & <stdio>) and also i tried specifying the whole path of stdio.h , nothing seems working
Sep 19, 2016
04:07 AM
Sep 19, 2016
04:07 AM
The stdio.h you are looking for is at tools/ARM_GNU/include/stdio.h
But you had better use the SDK's make file infrastructure to compile the code.
Otherwise, it's likely you will hit more issues.
Try adding VERBOSE=1 to build a snip code to figure out what the SDK does when
compile the code.
Sep 19, 2016
04:33 AM
Sep 19, 2016
04:33 AM
Hi , Thank you for your immediate reply , i try as you suggest.
