Has the roaming algorithm changed between the different wiced versions? We are seeing poor roaming performance (really long roams, and the devices sticking to APs with low RSSI) when we use wiced 3.0.1 with a BCM43341 vs using wiced 2.4 with a BCM433262.
We have our roam trigger set at -70 db on the device.
Can anyone comment on if we should expect a difference in roaming behavior?
- roam trigger
- roaming
We upgraded the image to the one found in WICED-SDK-3_1_2 and the roaming as well as the 5GHz performance increased. We are no longer having terrible roam times and constant disconnects.
