- Email to a Friend
Hi
We use WICED SDK 2.4.1 and the Inventek module ISM43362_M3G_L44 which uses the STM32F205 processor. We want to restrict maximum number of softAP client to 1. Where can I modify the code to accomplish this?
Thanks in advance.
- Email to a Friend
Testing a solution for your request.
Seyhan
- Email to a Friend
If you use the WiConnect firmware; the command you would use is
set http.server.max_clients <#> (if using long hand)
set ht s m <#> (if using short hand)
see: http://wiconnect.ack.me/2.1/variables?s[]=max&s[]=clients#http_server_max_clients
Inventek currently has not taken a licence on WiConnect from Sensors.com as of yet however so you would need to use the ACKme modules.
- Email to a Friend
Take a look at the this blog post Restricting Number Of Soft AP Clients
For testing you can use apsta snip application.
Seyhan
