WeWh_3706036
First like received
I am trying to add resources to the external filesystem (filesystem.bin) and I have configured the makefile per this example: Keep web content (.html, .js) on external flash in a filesystem .
The WIFI firmware  is contained within the Filesystem.bin and the resource files correctly show "RESOURCES_IN_FILESYSTEM".  However I cannot get the resources in the application to be part of the filesystem.  I am using the snip/resource read and I have tried  using :
LOCATION_CONFIGURABLE_RESOURCES += apps/resource_read/test_file01.txt
Additionally Platform_config.h contains:
/*  WICED Resources uses a filesystem */
#define USES_RESOURCE_FILESYSTEM
/* Location on SPI Flash where filesystem starts */
#define FILESYSTEM_BASE_ADDR  ( 0 )
My current Makefile is:
# Copyright 2018, Cypress Semiconductor Corporation or a subsidiary of
# Cypress Semiconductor Corporation. All Rights Reserved.
# This software, including source code, documentation and related
# materials ("Software"), is owned by Cypress Semiconductor Corporation
# or one of its subsidiaries ("Cypress") and is protected by and subject to
# worldwide patent protection (United States and foreign),
# United States copyright laws and international treaty provisions.
# Therefore, you may use this Software only as provided in the license
# agreement accompanying the software package from which you
# obtained this Software ("EULA").
# If no EULA applies, Cypress hereby grants you a personal, non-exclusive,
# non-transferable license to copy, modify, and compile the Software
# source code solely for use in connection with Cypress's
# integrated circuit products. Any reproduction, modification, translation,
# compilation, or representation of this Software except as specified
# above is prohibited without the express written permission of Cypress.
# Disclaimer: THIS SOFTWARE IS PROVIDED AS-IS, WITH NO WARRANTY OF ANY KIND,
# EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, NONINFRINGEMENT, IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. Cypress
# reserves the right to make changes to the Software without notice. Cypress
# does not assume any liability arising out of the application or use of the
# Software or any product or circuit described in the Software. Cypress does
# not authorize its products for use in any products where a malfunction or
# failure of the Cypress product may reasonably be expected to result in
# significant property damage, injury or death ("High Risk Product"). By
# including Cypress's product in a High Risk Product, the manufacturer
# of such system or application assumes all risk of such use and in doing
# so agrees to indemnify Cypress against all liability.
NAME := Platform_XXXXX_rev1
#Name  := Platform_CYW94343WWCD1_EVB
WLAN_CHIP            := 4343W
WLAN_CHIP_REVISION   := A1
WLAN_CHIP_FAMILY     := 4343x
HOST_MCU_FAMILY      := STM32L4xx
HOST_MCU_VARIANT     := STM32L476
HOST_MCU_PART_NUMBER := STM32L476VGT6
BT_CHIP          := 43438
BT_CHIP_REVISION := A1
BT_CHIP_XTAL_FREQUENCY := 37_4MHz
PLATFORM_SUPPORTS_BUTTONS := 1
ifndef BUS
BUS := SDIO
endif
VALID_BUSES := SDIO
# WIFI_FIRMWARE and WIFI_FIRMWARE_CLM_BLOB are now included into resources
# RESOURCES_LOCATION default to RESOURCES_IN_WICEDFS. But can be optionally config to RESOURCES_IN_DIRECT_RESOURCES
# WARNING: Config RESOURCES_LOCATION to RESOURCES_IN_DIRECT_RESOURCES will build firmware and blob to into main application
# and may cause internal flash to overflow
RESOURCES_LOCATION := RESOURCES_IN_WICEDFS
#EXTERNAL_MEMORY_RESOURCES = $(ALL_RESOURCES)
#ifeq ($(RESOURCES_LOCATION), RESOURCES_IN_DIRECT_RESOURCES)
#INTERNAL_MEMORY_RESOURCES = $(ALL_RESOURCES)
#GLOBAL_DEFINES += WWD_DIRECT_RESOURCES
#endif
GLOBAL_DEFINES += USE_ALT_FREERTOS
GLOBAL_DEFINES += USE_SABER
GLOBAL_DEFINES += BOOTLOADER_APP_LUT_NO_SECURE_FLAG
# Global includes
GLOBAL_INCLUDES  := .
GLOBAL_INCLUDES  += $(SOURCE_ROOT)libraries/inputs/gpio_button
# GLOBAL_INCLUDES  += $(SOURCE_ROOT)wiced/platform/MCU/STM32L4xx/peripherals/CMSIS/Device/ST/STM32L4xx/include
# Global defines
# HSE_VALUE = STM32 crystal frequency = 26MHz (needed to make UART work correctly)
#GLOBAL_DEFINES += HSE_VALUE=26000000
GLOBAL_DEFINES += $$(if $$(NO_CRLF_STDIO_REPLACEMENT),,CRLF_STDIO_REPLACEMENT)
GLOBAL_DEFINES += WICED_DCT_INCLUDE_BT_CONFIG
GLOBAL_DEFINES += WICED_DISABLE_MCU_POWERSAVE
GLOBAL_DEFINES += WICED_ENABLE_MCU_RTC
WIFI_IMAGE_DOWNLOAD := buffered
# Source files
$(NAME)_SOURCES := platform.c \
                   gpio.c \
                   adc.c \
                   tim.c
$(NAME)_COMPONENTS +=  inputs/gpio_button
$(NAME)_COMPONENTS += filesystems/wicedfs
JLINK_NATIVE := 1
# WICED APPS
# APP0 and FILESYSTEM_IMAGE are reserved main app and resources file system
# FR_APP := resources/sflash/snip_ota_fr-BCM943362WCD6.stripped.elf
# DCT_IMAGE :=
# OTA_APP :=
FILESYSTEM_IMAGE := $(OUTPUT_DIR)/filesystem.bin
# WIFI_FIRMWARE :=
# APP0 :=
# APP1 :=
# APP2 :=
# WICED APPS LOOKUP TABLE
APPS_LUT_HEADER_LOC := 0x0000
APPS_START_SECTOR := 1
ifneq ($(APP),bootloader)
ifneq ($(MAIN_COMPONENT_PROCESSING),1)
$(info +-----------------------------------------------------------------------------------------------------+ )
$(info | IMPORTANT NOTES        | )
$(info | Wi-Fi MAC Address        | )
$(info |    The target Wi-Fi MAC address is defined in <WICED-SDK>/generated_mac_address.txt                 | )
$(info |    Ensure each target device has a unique address.                                                  | )
$(info | MCU & Wi-Fi Power Save        | )
$(info |    It is *critical* that applications using WICED Powersave API functions connect an accurate 32kHz | )
$(info |    reference clock to the sleep clock input pin of the WLAN chip. Please read the WICED Powersave   | )
$(info |    Application Note located in the documentation directory if you plan to use powersave features.   | )
endif
endif
Zhengbao_Zhang
250 sign-ins First comment on KBA 10 questions asked
Hello:
I think we already put the resource files into filesystem.bin
echo ./tools/common/Win32/mk_wicedfs32 build/snip.resource_read-CYW943907AEVAL1F/filesystem.bin build/snip.resource_read-CYW943907AEVAL1F/resources/Staging/
below is the image:
Zhengbao_Zhang
Hello:
below is the image:
